Dead from Heat feels like you are in hell but you are only in an S13
Not sure about which FORUM? Drivers side window does not operate, I can hear the relay clicking. Tried to remove door panel. Screws, window switch are out panel is loose but I CANNOT REMOVE THE PANEL BECAUSE IT'S HUNG ON THE DOOR HANDLE AND LOCK. How do you remove this freaking panel without busting up the door? I have a FSM but no help?
Did you take off the little cover? If not it just prys off with a flatblade screwdriver.There are 2 "clips" that hold it on towards the back. one on top & one on bottom. Pop it off & you are home free.
The dude that had the car before me EPOXYED the Escutcheon plate, door panel toghter. Had use a Hacksaw Blade from long distance and cut the EPOXY away. Got the motor off Regulator cleaning the amature and brushes trying to get it to work. Used a meter and it has power all the way to the motor. Thanks for the help.
KeN VeRsUs RyU
Jun 10, 2005 07:38 PM
SINxSELEKTAH
Sep 7, 2004 12:53 PM
