?diagram for switch?
i need a diagram for this switch but i cant find it... i think i mite juss find the harness for it but i was planin to make one
i have a pic of the switch
its a switch from a 89 to 94 silvia fog light i think the coupe only has them
and the sil80
but i juss want to know which prong is which
http://pg.photos.yahoo.com/ph/yummie...bum?.dir=/2a00
and the sil80
if you can use a multimeter you could ghetto-rig it... i mean making simply an on-off switch regardless if your lights are on (these are for your fogs, right?).
take a multimeter and test each set of connectors with the switch on and off. when it's on/off you'll get continuity/no continuity. use those prongs and rewire the fogs. though, there could be issues of amperage, but not sure if that'll be a big problem.
