Electrical problem!
Old Aug 21, 2004 | 08:38 PM
BlckBeautyVTEC's Avatar
Electrical problem!
OK weirdest electrical problem happened to me today. I have an 89 240sx and my brake lights stay on even when i dont push the brake and when i turn of the car is still stays on. has any one else had this problem and if so how the hell do u fix it, right now i juat take out the fuse for the brake light when im not driving thanks
Old Aug 21, 2004 | 09:16 PM
Driftin RPS13's Avatar
have u looked over all the wiring starting from the bkrake pedal itself??? im betting there is a short to ground some where
also check over the wiring for the lights too the problem could be in there too
Electrical problems suck so good luck lol
Old Aug 22, 2004 | 12:44 PM
actually start backwards - start from the bulbs, and work your way back - older S13s somehow get shorts or wire corrossion in the back panel. chances are your problem is back there, before the main harness
Old Aug 22, 2004 | 05:50 PM
yeah, i should have said to start from the lights and work backwards hehehe my bad!
Old Aug 25, 2004 | 09:06 AM
DRiften's Avatar
its not the light bulbs, nor the wires.
the brake light is on because you might have LOW BRAKE FLUID.
yeah. thats a big issue. i am pretty sure, its that.
i had the same thing. the break light turned on one day. it took me like 2 days to check every single buld and wire.
and at the end, i accidently noticed i had low brake fluid. i added some. and it fixed the problem.
so as soon as you read this, go to your car, pop the hood and look at the brake fluid level. IF its somewhere around "minimum" go to PepBoys, or NAPA, and buy one bottle of brake fluid, and add some so the level is at maximum.
Make sure you buy the right brake fluid. (it shoud say what kind you need on the cap of the brake fluid container under the hood. i think its DOT3. but i am not sure so doublecheck)
peace.
Old Aug 26, 2004 | 03:06 PM
fist's Avatar
check if your bulbs are put in correctly..
make sure your pedal is actually not stuck on something like a floormat...if the pedal cant fully return to the position then obviously the light will stay on.
Old Aug 26, 2004 | 03:28 PM
fist's Avatar
from what i understood...his actual brake lights on the back of the car are staying on. not the brake warning light on the dash.
Old Aug 26, 2004 | 10:07 PM
djradam's Avatar
if his brake pedal was pushed down, i think it'd be hard to drive.
Old Aug 27, 2004 | 12:06 PM
fist's Avatar
it only has to be pushed down about half an inch to make the lights turn on....alot of brakes dont even effect velocity when they are only pushed enough to trip the switch
uvamosk
Aug 12, 2005 07:31 PM
shaughn
Jul 28, 2004 07:41 AM
war
Jun 19, 2004 07:02 PM
kaos
Jan 14, 2004 01:38 PM
s240r
Aug 13, 2003 03:29 PM
