Electrical problem?
Old Jul 15, 2005 | 12:32 PM
Markdawg20's Avatar
Electrical problem?
As i start the car all things electrical jsut seem to fail half way through the car starting process...the car just goes dead.
The starter just stops cranking, the power seatbelts get stuck half way through the track, all power goes out.
I remedy this easily by disconnecting and reconnecting the negative battery terminal and i am able to start it right up.
This has only happened twice and does not happen often, but it concerns me. Help a brotha' out please.
Old Jul 15, 2005 | 12:59 PM
ramnailz's Avatar
Well, first thing is first. Your battery. Is your battery old/ clean? Check to see if it still has atleast 12v. Use a multimeter/voltmeter. If thats good, do a visual inspection of your battery to see if there is any leaks or if your battery terminals are dirty. You could use an old toothbrush and some baking soda and water in a cup or something and clean your terminals. If that isn't it you should check your battery wiring, I know some people who this happened to. You should check for tears in the wiring or any contact, if theirs any electrical tape or anything else you might want to check that out and see if thats the issue. Other issue's might be other wiring, starter, alternator. Just start from the beginning, so you know for sure, I hope this helps later
Old Jul 17, 2005 | 01:08 PM
Markdawg20's Avatar
Could be the battery...ill check
Old Jul 17, 2005 | 04:09 PM
Preston's Avatar
Sounds like a bad ground to me...check your ground wire and terminals. Are they corroded or rusted or even connected solidly? Clean them off and reconnect them tight, but not so tight that you break the threads. If that doesn't work, then try the battery and replace if neccessary.
uvamosk
Aug 12, 2005 07:31 PM
shaughn
Jul 28, 2004 07:41 AM
war
Jun 19, 2004 07:02 PM
kaos
Jan 14, 2004 01:38 PM
s240r
Aug 13, 2003 03:29 PM
