Electrical Problems Help!
Recently i took off my rear hatch on my '93 h/b to fiberglass the spoiler holes. i cut and individually capped the wires leading into the hatch, but now that its back on, my automatic seat belts and my cd player dont work, WTF!!! i cant understand why ,everything else works (headlights,dash lights,a/c ,inside lights) i capped them off seperatly and i dont understand how this could be happening.
yea i know , i figured that but i cant find a blown fuse anywhere... ....anyway the "audio" fuse is fine and everything else works, if it was a different fuse, something else wouldnt work.- i am guessing that i fried or shorted something before the fuse could blow.
And if I remember right your warning chimes shouldnt work either. Ill bet you 100 bucks its a fuse i had the exact same thing happen only working behind the dash.
haha yeah same thing happened to me...and i still haven tfound the culprit. i was working behind dash and think i shorted soemthing.. Replaced the fuse but radio, click, Interior light, Warning chime, and auto seat belts(only works if door is open and Key is in ON position) dont work.
yea PROBLEM FIXED its not the audio fuse, its the third fuse down on the right. Its listed as an inside light/accesory fuse. i had the same problems no chimes, no seatbelts, just replace that 10amp fuse and its all good.- by the way i blew it when i cut through the co-axial wire for the defoggers, the outside and inside touched the instant i cut it.
EDIT: the correct fuse is the only one highlighted in white on the chart on the inside of the fuse panel.
