engine's pissed i washed it
Old Apr 20, 2005 | 08:46 PM
marcelft's Avatar
Help. 92 240 SE, stock engine. So, I washed my engine today. yes, I covered my distributor with a grocery bag, but still managed to get distributor wet!! It started, ran like poo poo, so I popped the cap off, dried it off, replaced cap, and it still ran like poo-poo, not as bad as before, but misses, lacks power off the start, has lots of hesitation, bucks, has moments where it starts to feel like its acceleration just fine, then cuts back. What's going on?? This was at noon, and its 12 hours later, still acting the same. Ive had the cap off like 5 times, and the plug wires. I figured if it were water someplace it would have dried up by now. I have spark going to every plug, tonight I checked it at idel by pulling spark plug "boots" and watching the arc to the valve cover.
So, anything else I may have gotten wet that would make my car run like that? Any ideas
Old Apr 20, 2005 | 09:57 PM
smokie700's Avatar
airfilter?
Old Apr 20, 2005 | 10:22 PM
Waynehead05's Avatar
it's the spark plugs. you need to replace them and spray some wd-40 in the chambers to dissapate the water. it'll pass through really quickly. then just go cruisin so the engine can heat all the way up and it should be fine.
i'd be surprised if this wasn't it because i've washed my altima engine twice and did this twice.
hope it works for you.
Old Apr 21, 2005 | 07:15 AM
marcelft's Avatar
Airfilters fine, it never got wet as it was in it's stock air box. I pulled the plugs like you said, they didnt look wet at all. Car's still acting up. Check engine light is not coming on. Car's exhaust smells nasty. Damn I frikking hate when stupid crap happens like this!!
Old Apr 21, 2005 | 12:58 PM
Yoshi_Sil40's Avatar
check for error codes
Old Apr 21, 2005 | 08:08 PM
marcelft's Avatar
My check engine light is not on, could there still be error codes???
Old Apr 22, 2005 | 01:15 PM
marcelft's Avatar
Problem FIXED. I noticed a crackeling noise when i turned on my Radio (which I rarely ever do), and remebered that plug wires have a coating to prevent radio interference. stopped by Nissan to see how much plug wires were $130.00!!!!! Went to Auto Zone, $41.00. Replaced wires, cap, and rotar..problems went away immediately. When I had taken cap off to dry it out, I must have cracked a tired plug wire.
EJ253
Feb 3, 2007 01:21 AM
CrAcKHeAdBoB
Dec 1, 2005 02:28 PM
God
Nov 10, 2005 04:00 PM
Bryan
Jul 24, 2003 06:01 AM
2-FORTY_TERROR
Feb 26, 2003 08:19 PM
