Failed smog on s14
I got a stock s14. Just recently tuned up as well. Fail smog testing today. High HC and High CO. Perhaps shady smog tester? Here are the numbers:
15mph test: HC=440. Max is 88 CO=11.68 Max is .52 25mph test: HC=466 Max is 53 CO=12.22 Max ix .50 I forgot to run the car a few minutes before pulling up to the shop. Cold cat perhaps? I heard of this HEET fuel anti freeze may increase the chances of passing smog. Does it work? Ehhh not sure what to do. |
cat still good?
o2 sensor good? |
I just checked my ecu codes. I got 34 and 76.
The knock sensor and the fuel injector system. So I should change my knock sensor. But how should I go about checking the fuel injector system? |
