Failed smog on s14
Old Oct 1, 2008 | 01:37 PM
woofywolfer's Avatar
Failed smog on s14
I got a stock s14. Just recently tuned up as well. Fail smog testing today. High HC and High CO. Perhaps shady smog tester? Here are the numbers:
15mph test:
HC=440. Max is 88
CO=11.68 Max is .52
25mph test:
HC=466 Max is 53
CO=12.22 Max ix .50
I forgot to run the car a few minutes before pulling up to the shop. Cold cat perhaps?
I heard of this HEET fuel anti freeze may increase the chances of passing smog. Does it work?
Ehhh not sure what to do.
Old Oct 3, 2008 | 02:16 AM
Drift Motion's Avatar
cat still good?
o2 sensor good?
Old Oct 9, 2008 | 04:36 PM
I just checked my ecu codes. I got 34 and 76.
The knock sensor and the fuel injector system.
So I should change my knock sensor. But how should I go about checking the fuel injector system?
SupraMan
Mar 30, 2006 10:38 PM
KarateBoy
Nov 25, 2005 09:48 AM
Cape 240
Nov 5, 2005 06:35 PM
rb26dett
May 11, 2005 05:18 PM
epoxy
Feb 23, 2004 09:28 PM
