Fix your hatch using JB Weld and sheet metal
Ok I decided to try the JB weld way of fixing the rust on my hatch and I thought I would share it with everyone on here.
Suplies needed. I actually have 3 things of JB weld and I forgot to put the file in there but you get the idea. I have some extra material left over and all this ran me about $50.
The reason for the job...
To remove the duct tape.
Scary isn't it?
After nearly 2 hours of sanding with 80 grit.
After cutting away the rusted threw portions and filing down loose ends. You want to cut the rusted threw parts away last or it makes it harder.
Shape the metal on the outside of your car with a hammer so you get the curve of the trunk right.
I found that it was easier to mix the JB weld on the actual piece of metal to be put in the trunk then it was to mix it and transfer it.
When the JB weld says it gets hot as it's curing it's not lying. You have to hold it in place for like 3-4 minutes so I sugest wearing some gloves. Right now I have about 3/4 hours invested in this but you could move a lot quicker if you have a dremel tool/ grinder. I'll post more pics tomorrow while I'm bondoing and painting. If you have any questions PM me.
Scary isn't it?
looks GREAT
i was gonna post mine up, maybe we could combine them because on mine, i fixed the holes of the third brake light and wiper, but basically same procedure.
shiet we should compile a sticky on DIY things like this.
Originally posted by dak2007
isn't it illegal to get rid of the 3rd break light? this might should be a sticky...
A missing brakelight would be the least of my concerns if I got pulled over haha
Originally posted by nsn240
i dont think so... bomex180 doesnt have one.
Awesome write up so far, I'll sticky it soon and then send a cleaned up copy to the FAQ section.
As promised here is an update of today so far.
I put bondo where bondo needed to go. As you can tell from the pic one of the holes doesn't have bondo yet. That's because I didn't like the way the JB weld set up last night so I redid it.
Almost done with the first round of bondo and sanding. Oh wait this is why you don't get in a hurry while working on your car. I didn't let that one patch fully cure (4-24 hours recomended) and it fell threw.
So right now I have put some more bondo on the areas I've already sanded down. I'm waiting on that to dry so I can go final sand that. Then I have to wait probably untill tomorrow so I can do the bondo/ sanding process on that one last patch.
see it works doesnt it?
remember after you do the basecoat to wetsand through 1000 grit or so and then clear coat it.
i would remove the 3rd brake light aswell. you can always extend the wires into the cabin and put an led strip behind the back seat or something
I don't mind the 3rd brake light. As far as paint goes I think I'm just going to primer gray the hatch for now. I don't want the hatch being the only part of the car with a half decent paint job.
After all the bondo/sanding is done.
From another angle.
With some paint on her.
Now all I have to do is a little wet sanding. I realized just how ****y it looked after I painted it and you can tell exactly where all the bondo is. I need to fan that out just a little bit more.
From another angle.
slidewithpride
Aug 12, 2011 09:51 AM
booyah0303
Feb 5, 2004 05:52 PM
RUTH'LESSDET
Dec 4, 2002 03:14 AM
