GUIDE: Installing a Performance Radiator
Old Dec 26, 2005 | 11:33 AM
PNG's Avatar
PNG
Actually, a cap with a stronger spring puts the system under more pressure, which does raise the boiling point of the coolant. The downside of a high pressure cap is that it puts more stress on the system, possibly leading to leaks or even blown radiator tank seams. It's not a great idea to put a higher-than-stock cap on a car with an old, OE radiator, old hoses, etc.
Old Dec 26, 2005 | 12:51 PM
nsn240's Avatar
Originally posted by l2aine
I dunno about this whole thread.
Title should have been something like "change a radiator on your SR fanless engine swap".
ok? dont really get that, but...
Plus you didn't bleed the system, that's like the most important step when changing radiator fluid and/or radiators.
the engine swap had just been completed, and we bleed the system (~200mi) earlier and used the same coolant, i didnt think completely flushing the system was neccessary in my case
Kinda funny how you strongly recommend upgrading or changing to an electric setup during the swap . Why? Is it because the clutch fan really doesn't work? Or because you have an efan and have no real idea how to do the job on a car that has a clutch fan? =P
no, i know how a clutch fan works, and works well. i suggested upgrading to an electric setup to help cool the engine more efficiently, and take out the added "stress" (right word?) that a clutch type fan uses, since it runs off the crank.
(BTW KA or SR, if you have a clutch fan all you have to do is remove the fan shroud - not the whole fan as this thread states)
thanks, i didnt know that, since i dont have a shroud ( i should get one though)
Oh and changing radiator caps does not "raise the boiling point". What it does is change the point at which the cap opens up to release excess coolant to the resevoir.
^read above
hotimportknight
Jan 9, 2005 10:58 PM
vegita319
Aug 23, 2004 06:12 PM
MoxMonkey
Mar 29, 2004 04:03 PM
unstoppablenick
Nov 15, 2003 01:37 AM
2FortyessX
Feb 11, 2003 07:36 PM
