hatch sounds. annoying...
Hey guys. I have a 91 se hatch. Ever since I got my coilovers every bump I go over it sounds like my hatch is lifting up and slamming back down onto the frame. It sounds pretty bad.
I was wonder if anyone else has encountered this kind of problem. And if so I would like to know any solutions to fixxing it. Any help would be much appreciated.
Thank you in advanced.
put more rubber between the hatch and the rest of the car. the hatch cant slam back down if there is pressure being applied upwards when it is at the highest point it can be when closed.
and wtf is a kamikazi?
haha im japanese
i was kinda giving him a hard time because he spelled it wrong
its kamikaze
it literally means god's wind
kami = god
kaze = wind
and contrary to popular belief kaze is pronouced ka-zeh
its kamikaze
kami = god
kaze = wind
correct,
try getting a set of subframe spacers
www.splparts.com
or even ebay ones work as long as they fit.
www.splparts.com
if i just get the subframe spacers then i won't need subframe bushings?
if i do need bushings also, then is it better to go with polyurethane or aluminum? don't aluminum bushings make more noise though?
sorry for all of these questions. im still new to these things.
You don't need to get bushings if you get the spacers, you can run them with your stock ones. Anything more stiff than the stock bushings will produce more noise. Aluminum/Solid bushings being the worst.
spacers = solid bushings
get that for a rougher but better handling ride
polyurethane inserts for a streetable ride with improved handling
it all depends on the trade off youre willing to make and live with.
