headlight problems
alright there are two actual lights in the headlamp... the inside one (closest to the grill or the center) works fine but the outside ones dont seem to. i just replaced them about ten minutes ago and still nothing. and either do my cornerlights. i cant seem to get the actual headlamp out cause i got the front mount and the screw holding it to the corner light but what else is there. if i could get it out i might be able to figure this out.
eny help would be greatly apreciated |
Re: headlight problems
Originally posted by C-Walk alright there are two actual lights in the headlamp... the inside one (closest to the grill or the center) works fine but the outside ones dont seem to. i just replaced them about ten minutes ago and still nothing. and either do my cornerlights. i cant seem to get the actual headlamp out cause i got the front mount and the screw holding it to the corner light but what else is there. if i could get it out i might be able to figure this out. eny help would be greatly apreciated It's odd that your highbeams work but your regular beams don't - when the light stalk is at high, the regular beams are supposed to light up also. About your corner lights, in the schematic they're wired up with the rest of the parking lights, so if your taillights light up at night, my best guess at this point is that there's possibly some cut wires to both the regular beam bulbs and the corner lights, provided that you replaced all 4 bulbs and they still dont' work. BTW the inner bulb (closest to the grille) is the high beams. |
raine, what do you mean by "It's odd that your highbeams work but your regular beams don't - when the light stalk is at high, the regular beams are supposed to light up also. " ?
when i put my high beams on, my regular beams turn off (i'm pretty sure of that....) |
Originally posted by djradam raine, what do you mean by "It's odd that your highbeams work but your regular beams don't - when the light stalk is at high, the regular beams are supposed to light up also. " ? when i put my high beams on, my regular beams turn off (i'm pretty sure of that....) |
I have a '95 and mine alternate also.
low on=high off high on= low off It may be that yours is an SE Raine. IMO. But your problem does seem kinda weird.... |
Originally posted by SR20detoofast4u I have a '95 and mine alternate also. low on=high off high on= low off It may be that yours is an SE Raine. IMO. But your problem does seem kinda weird.... |
