Help!
Old Oct 10, 2004 | 08:19 PM
SLOazzEPhatch's Avatar
Help!
Just wondering how you can tell when your MAF is bad? please help!!
Old Oct 10, 2004 | 09:22 PM
DRiften's Avatar
-if your engine works like sh*t.
-you cant go over about 3000 RPMs
-huge power loss
-sudden stalling
-takes a long time to start the engine
-usually check engine light is on
Old Oct 10, 2004 | 09:30 PM
it does run like sh*t,
it can't go over 2500rpms,
stalls if you don't keep your foot in it,
and the check engine light is on.
couldn't this mean the timing is off too? just wondering.
Old Oct 10, 2004 | 09:45 PM
DRiften's Avatar
its your MAF.
timing wont do all that bad stuff.
but before i would go out and buy a new MAF, i would check the plug that its right on the sensor. even if it looks plugged, make sure its in ALL THE WAY. sometimes, friends like to joke around, and unplug it. bad bad friends.
so check all the plugs first. if errything is aiiit, buy a new MAF, replace it, drive it like you stole it.
Old Oct 10, 2004 | 09:48 PM
lol. ok then. maybe i should put everything back together then. Where would you suggest going to get a new MAF? no regular parts stores have it.
Old Oct 10, 2004 | 09:51 PM
Jedi Mind Gamez's Avatar
i just got a mafs at autozone yesterday...
Old Oct 10, 2004 | 09:53 PM
really? does it work good? is there a warranty on it?
Old Oct 10, 2004 | 09:56 PM
DRiften's Avatar
i know the dealership has it 100% but its gonna cost ya a bit.
so before you go there, check all those little stores like NAPA, PEP BOYS, AUTO ZONE, ADVANCED AUTO PARTS....
but before you even check that, please check the plug first. someone did a prank on me and disconnected the MAF sensor plug. and you couldnt even tell, cause it was like removed just little bit, it was still on but it didnt have the connection. so i almost but the freakin MAF, but they told me about it.
so do that first.
Old Oct 10, 2004 | 09:59 PM
oh i will, don't worry. it isn't like i am made out of money. I am just going to put everything back together tomorrow, because i had started a break down of the motor to check the timing. It started raining though, so i didn't get too far.
Old Oct 10, 2004 | 10:08 PM
DRiften's Avatar
you dont have to brake down the motor to chec/adjust the timing.
dude, i dont know how you call this thing but follow the plug wires from the spark plug to this thingy. i forgot how you call it shoot. but its gonna have 5 wires coming our of it and it sits on the right side of the valve cover.
its gonna have 2 bolts. if you unscrew them to a point where you can move that whole thing... thats how you undjust you timing.
start the engine, let it idle (is you fix the MAF problem) and play with the timing. the best setting is if you live it in the middle (theres a scale next to the bolts that you unscrewed).
if i am wrong and you are tolkin about the other timing.. then tell me that.
Old Oct 10, 2004 | 10:11 PM
i am talking abotu if the timing chain has jumped a tooth. then you would have to check the chain itself. lossen it and adjust it accordingly....and you are tlaking about the distributor no?
Old Oct 10, 2004 | 10:19 PM
DRiften's Avatar
exactly. distributot. thank you. ok, yeah you should defenitely check the chain if it jumped a tooth.
Old Oct 10, 2004 | 10:20 PM
i duno if it has or not, but i might as well check now. i have it almost torn down all the way.
Old Oct 10, 2004 | 10:25 PM
DRiften's Avatar
go for it. then tell us what you've seen from the expedition inside your motor and what you've done. maybe i will have the same problem one day.
Old Oct 10, 2004 | 10:32 PM
hahaha ok
