Help! with electrical system
Old Nov 23, 2003 | 11:31 AM
manferd's Avatar
i've been having this problem where it seems there's no power when i put the key in the accs on position (2nd position). ANd usually when I open the door, the auto seat belt moves towards the front of the car, but now I need the key in the 3rd position for that to happen. Also, the clock on my instrument panel only turns on when the key is on the 3rd position and the driver door is closed. One last thing, my radio doesnt work at all anymore. If anyone can help, I'd appreciate it
Old Nov 23, 2003 | 12:33 PM
For your radio did you check all your fuses? I'm not to sure what the problem could be
Old Nov 24, 2003 | 08:18 AM
OverBoost's Avatar
check all your fuses under the hood and behind the drivers kick panel. did this just start happening by itself? sounds like your ignition went bad, but they can be replaced pretty easily. go to your local junkyard and see if you can score one and try it out, if not, take it to a mechanic.
Old Nov 24, 2003 | 06:42 PM
manferd's Avatar
I checked my fuses, and found out the 75 A fuse (ALT) blew out. Where can I find this fuse, because I went to Kragen and Pep boys and they both dont stock this fuse
Old Nov 25, 2003 | 03:26 PM
manferd's Avatar
ok, I replaced the fuse but i still have this problem. Is there something i have to do after replaceing the fuse? I'm hoping i didnt destroy my alternator or something
nissans13
Aug 23, 2006 02:54 PM
240mph
Aug 20, 2005 08:50 PM
clikzip
Jul 17, 2004 07:24 PM
kaos
Jan 14, 2004 01:38 PM
s240r
Aug 13, 2003 03:29 PM
