help with gauge lighting
Old Nov 18, 2004 | 09:48 PM
240yoda's Avatar
Question help with gauge lighting
Ok so this has probably been asked a grip but here I go
i have a 91 s13 with the hud the gauge lighting has gone out actually its been out. sometimes when i hit a bump it comes back on for a few seconds the out again. mostly it stays off.
if anyones come across this and fixed it i would appreaciate the help.
Old Nov 20, 2004 | 02:38 PM
Re: help with gauge lighting
Since you said that it goes on and off intermittently, it's still working - wiring harness might be loose. check connections.
Old Nov 22, 2004 | 12:37 AM
240yoda's Avatar
OK the harness is in tight nothing looks frayed.
ive heared that it could be the dimmer switch but my HUD will get
dimmer or brighter. im puzzeled
Old Nov 22, 2004 | 11:12 AM
NismoKa's Avatar
Never looked at one in my life before, but I know with electronics occasionally cold solder joints detach. But usually stay close enough so that a bump will fix the problem. I've seen this in car cd player, amplifiers, tv, etc.
Old Nov 22, 2004 | 07:26 PM
240yoda's Avatar
ill check the joints thanx
Old Nov 22, 2004 | 11:57 PM
this may sound elementary, but check the fuses for the instrument panel. Sometimes fuses look good, but they're so old that something gets weird in them; I had a problem similar to yours on my last car, and I replaced the fuse (which wasn't broken) with a new fuse of the same rating and it fixed the problem
Old Nov 23, 2004 | 11:35 PM
240yoda's Avatar
oh man if ill try that thanks
Old Dec 4, 2004 | 07:06 PM
240yoda's Avatar
didnt work. goin to junk yard tommorow well see
Old Dec 7, 2004 | 03:24 AM
Whisper's Avatar
well... i've been stuck with my nissan with no digi cluster and no HUD... niether have worked... and i've had my car for about 8 months... i don't even have dash lights.. when i first got her i had some lights that flickered.... and at that time i also had cruise controle.. cruise went out at the same time i lost dash lights all together.... every fuse is new, and i've pulled my dash lights out and checked it inside and out with a wire tester.. everything works, all bulbs r good... but nothing...
i know this is u'r thread.. but if u find out any info u wanna keep me informed.. it's annoying goin by the RPM's...
Old Dec 9, 2004 | 10:06 PM
240yoda's Avatar
my cruise still works all the warning and signal lights still work also the dimmer still controls the brightness of the spedo and HUD but no dash lights
Old Dec 9, 2004 | 10:10 PM
240yoda's Avatar
also dont have enogh to pay 80$ per hour on top of what it would take to fix cause im bettin its mostly labor and labor always cost a grip
Old Jan 8, 2005 | 09:36 PM
240yoda's Avatar
if someone has been trough this i would appriciate all the help you can give me
Old Jan 23, 2005 | 04:03 AM
wikd240's Avatar
here is what i found on this problem... im trying it today...
http://multi-index.myonlinesite.com/...0sx_speedo.htm
Old Jan 25, 2005 | 02:47 AM
wikd240's Avatar
did not work for me going back thru it tonight to see if i messed up or something...
Old Mar 14, 2005 | 06:25 PM
240yoda's Avatar
im still stumped went to the junk yard and came aross another 240 with a digital cluster. so i took that and the subharness behind it replaced my old cluster and harness but the gauge lighting still blinks out
ryguy
Oct 2, 2007 08:59 PM
240freak88
Aug 15, 2007 09:25 PM
240mph
Aug 20, 2005 08:50 PM
DTS
May 24, 2004 02:53 PM
clts14.5
Nov 29, 2003 12:21 AM
