help! ignition problem
Old Feb 26, 2006 | 08:14 AM
nautica_t's Avatar
Exclamation help! ignition problem
hey guys, i have a short somewhere that sometimes allows me to turn on the car and sometimes it doesn't. its really wierd. sorry its a 1989 240sx coupe. no engine swap, factory motor.
when it first shorted it out the black/white wire on the iginition key cylinder melted off the solder. i solder it back up and it worked, however, sometimes it shorts again and i can't start the car. i wait a bit and viola i can start her up again. oh yeah the 30amp ignition fuse keeps blowing no matter what.
i have a couple of questions.
1. can the ignition relay be a problem causing the short.
2. can an aftermarket head unit cause this problem.
3. where does the ignition wire run though, i mean everything, i'm debating about running a new wire for the ignition, yes or no?
thanks guys, i really need to fix this situtation.
got_psi?
SR
Apr 24, 2010 12:29 PM
rps13VEk
Jan 3, 2007 07:13 PM
240m3srt
Oct 4, 2006 11:26 PM
uvamosk
Aug 12, 2005 07:31 PM
