Help. Passenger side headlight not working.
Old Jul 26, 2003 | 02:14 PM
wrxwgn03's Avatar
Okay. My friend has a 92 240sx se and the passenger side low beam doesn't work. The motors work like they are supposed to. And the high beams work just fine. We already tried replacing the bulb and that didn't fix it. I think it's a relay somewhere, since we did check all the fuses as well. Does anybody know if this is a known issue. Or could tell me exactly what the problem is?
Thanks
Old Jul 27, 2003 | 03:46 PM
rudeboy's Avatar
just look in your FSM and check the relay's
i know that the S13 has a relay for drive and pass side.
could be that or a short.
just check the local wireing and then the relay.
good luck
Old Jul 27, 2003 | 05:19 PM
StanBo's Avatar
Unplug your bulb and stick either a test light or a fluke in there to make sure you are getting a feed. If not check the line. There are fuses in the driver compartment and the engine bay.
cesaturn95
Oct 17, 2009 02:16 PM
WhoDiddy
Feb 6, 2006 07:07 PM
KerosineK
Nov 12, 2005 11:31 AM
yektik99
Feb 16, 2005 06:49 AM
SaGang227
Oct 25, 2004 09:50 PM
