HELP!!! With Starter
Old Jun 21, 2005 | 06:36 PM
DraFt's Avatar
I just bought a JDM engine for my 89 nissan 240sx.. i got the engine bolted down and everything then i went to put the starter from my old engine into this new JDM engine and the starter is to big!! The new block has another section on it that the starter goes through. Can someone tell me if i need to buy a new starter or do they make a nose cone replacment?
Old Jun 21, 2005 | 06:59 PM
lrb_2000's Avatar
umm, by JDM do you mean sr20det? or what... because i'm pretty sure the starter from your old engine (assuming it's a ka24e) isn't going to fit... you'll most likely have to find someone parting out an sr20det or order a new starter.. you might wanna check and see if a starter from an (sentra se-r, nx2000, ect..) sr20de would fit...
Old Jun 21, 2005 | 07:04 PM
DraFt's Avatar
no i dont have the Turbo (sr20det). It's the black top. not a red top. I have no idea why this starter wont fit. I found a starter online that is suppose to work from a 1989-98 and it looks like the same deal as the one i have.. But this Starter just wont fit. Its to big
Old Jun 21, 2005 | 07:07 PM
SHIFT_Sideways's Avatar
hahahahahhhhhahaahahahahahh hahahahah a holy ****ing ****!!!1 hahaahahahahah no **** it wont ****ing fit!!!!!!
Old Jun 21, 2005 | 07:13 PM
DraFt's Avatar
Old Jun 21, 2005 | 07:14 PM
lrb_2000's Avatar
of course it doesn't fit, it's for a different motor... you have to get a starter from a JDM RWD SR20DE...
They have starters from FWD SR20DE's here for $40.. don't know if they'll fit though, you'll have to search.
http://www.jgycustoms.com/serg20/oem.htm
Old Jun 21, 2005 | 07:16 PM
DraFt's Avatar
But i dont have the turbo sr20det.. Thats the turbo aint it?
Old Jun 21, 2005 | 07:23 PM
lrb_2000's Avatar
sr20det is turbo... sr20de isn't... Which motor do you have?
20 = 2.0 Liter
D = Dual Cam
E = Electronic Injection
T = Turbo
Old Jun 21, 2005 | 07:24 PM
DraFt's Avatar
I have a nonturbo
Old Jun 21, 2005 | 07:27 PM
DraFt's Avatar
its a 2.4L
Old Jun 21, 2005 | 07:29 PM
lrb_2000's Avatar
I'm confused. If it's 2.4L then it's the KA24de which isn't JDM... It's USDM and came in 91+ 240sx's ... What year car did your engine come out of?
Old Jun 21, 2005 | 07:32 PM
DraFt's Avatar
its suppose to have came out of a 89 nissan 240sx! I got the engine from www.asapmotors.com they are closed right now so i cant tell for sure.. its suppose to be a JDM.. its not a turbo tho. It looks a little diffrent then the engine that was in my car.. the motor mounts are diffrent and this engine looks a little newer
Old Jun 21, 2005 | 07:33 PM
DraFt's Avatar
But like i said before.. my car is an 89
Old Jun 21, 2005 | 07:38 PM
lrb_2000's Avatar
Well if it's the same engine that was in your car the starter should be the same... anyway you can get a picture?
does it look liek this?
Old Jun 21, 2005 | 07:43 PM
DraFt's Avatar
Yes yes thats the engine right there.. thats the one i have... its the same one that came out of my car but the starter from the old engine wont fit the new engine..
