hood question
Old Jan 10, 2005 | 11:57 AM
cmhadley's Avatar
hood question
When i'm driving on the highway, my hood acts like it is going to fly up, like it physically moves up and down...I went through and checked all the bolts and they were all tight but when I compare the hood's position relative to the fender lines, the hood never goes ABOVE the fenders, it is going low then back to flush...it prolly moves down a 1/4" or so, just enough for me to notice and get nervous. Is there a fix for this?
Old Jan 10, 2005 | 12:48 PM
2fast4y0u's Avatar
rubber spacers that are bigger then whats factory.
i use rubber bicycle grips. just make sure if you are going to do this that you get some soft rubber ones. very cheap adn its and easy fix
Old Jan 10, 2005 | 12:54 PM
shane_lxi's Avatar
I read somewhere that if oyu lift it above the fenderl ine you get quicker cooling. Wouldn't have thought it if I just saw a car with it done. My 91 did that too. Just a slight move, almost not even noticable, and everyone in the car htinks your crazy when you say you saw oyur hood move.
Old Jan 11, 2005 | 01:08 AM
toycar49's Avatar
those lifted hoods just look broken imo =P
Old Jan 11, 2005 | 03:55 AM
On shorter hood cars (i.e. 200SX) it looks like the car rear ended someone.
I have the hood lift mod thingy on my car, it seems to cut the engine temp down a little... the cool part is seeing the water jump from the hood to the windshield while you're driving, heh...
...then again I should be watching the road
Old Jan 11, 2005 | 04:44 AM
Darchangel's Avatar
...then again I should be watching the road [/B]
heh....mine does that too
a good hood wax helps ofc....and then ya hit the highway early morning with all the dew on the car
Old Jan 11, 2005 | 04:47 AM
hahah yeah... one time I said, "hey that looks cool" and pointed at the water... my girlfriend just gave me that "...sure pal." look
Old Jan 11, 2005 | 12:10 PM
cmhadley's Avatar
so you guys are lifting the stock hood height? I havent heard of that one before, but it would work...it's pretty cold up here in Indiana so when the weather warms up a bit i'll give the rubber mounts a look at. Thanks for the ideas
thirdclass
Aug 14, 2006 07:47 PM
Carparthookup
Oct 17, 2005 01:30 AM
eerrrrr
Sep 28, 2005 07:27 PM
badman70_1
Jan 26, 2005 05:33 PM
180sx
Oct 6, 2003 03:20 PM
