How Can I tell if my ECU is Auto or Manual?
Old May 17, 2007 | 07:18 AM
Alen's Avatar
The problem is, I have 2 ECU's: one's auto and one's manual.
From my understanding, it'll work in my manuel car but the auto will pop the check engine light.
The thing is, I think something's up with my engine and it's popping up for both ECUs so now I don't know which one is which.
Thanks for your help in advance
Old May 17, 2007 | 02:33 PM
Durdan's Avatar
an auto ecu wont trigger a check engine light. if you have a light on, somethings wrong.
Old May 17, 2007 | 05:04 PM
Alen's Avatar
oh thanks
maybe there's just something wrong :/ uhmmm
is there a way to tell the difference between the two though?
should both of them work the same for my stick 240sx?
Old May 17, 2007 | 08:02 PM
An auto ECU will work just fine in a 5 speed. Its only a problem when you put the 5 speed ECU in the automatic. If both ECUs are making the check engine light come on I'd say the problem is something else. Run the codes on them.
Old May 18, 2007 | 01:03 AM
the auto ecu will remove the speed and rpm limiter.
Old May 18, 2007 | 08:43 AM
Durdan's Avatar
incorrect.
you can tell which is which by the large 2 digit code on the side of the ecu case. 28 is a twin cam KA 5 speed... pretty sure 29 is twin cam auto
MasterOSkillio
Mar 7, 2006 03:21 PM
bcvjj21
Oct 30, 2005 12:00 PM
spoolin240
Apr 13, 2004 09:46 PM
