Need Help: Injector Removal
Old May 18, 2007 | 07:25 AM
trevr's Avatar
Did some research, but couldn't find any detailed info on removing injectors from my CA18DET.
I need to replace my injectors, and need some pointers of how to do it correctly. I have looked through the FSM, and know the proper way to release fuel pressure. Mainly, I need to know what I need to remove to get to the injectors. Any help will be greatly appreciated!
Old May 18, 2007 | 10:05 AM
take off the injector harness clips, unscrew the two screws holding the plate and injector onto the fuel rail. then use two small screwdrivers the pry the injector up using the small slots on either side... it will probably be in there pretty well. personally i use pliers instead shaped like this:
similar to the ones labeled zp-13
to install the new injectors use some motor oil or engine assy. lube and give the lower and upper orings a generous wetting.
Old May 18, 2007 | 01:55 PM
trevr's Avatar
Will Injectors for a 1991 1G Mitsubishi Eclipse GSX drop right in as replacement for CA18DET?
Old May 18, 2007 | 02:06 PM
those are top feed and high impedence, so no.
Old May 18, 2007 | 02:11 PM
trevr's Avatar
Thanks silviaks2nr
I'm still under the impression that the ca18det uses top feed injectors.
Old May 18, 2007 | 02:50 PM
it may be top feed, you would know better than me. There are serveral devices on the market that convert the signal to low impedence
revolutionz_s13
Feb 21, 2013 08:21 PM
homesliceisj
Jun 22, 2007 02:50 PM
revolutionz_s13
May 6, 2006 05:46 PM
Choppa'
Apr 3, 2005 01:25 AM
Malory
Sep 10, 2004 03:42 PM
