I need help
I need help
ok, so my check engine light went on a couple days ago, and i looked under the hood and at the engine and everything seems to be normal. it isnt making any noises or anything like that. I know about setting the ecu to diagnostic mode and reading the code urself but i dont really want to mess with the ecu. I want to know where you would plug in the diagnostic reader into the car so i can get the code. i looked under the kickpanel on the passenger side but i dont see anywher to plug it in to. Please help
Re: I need help
If you're gonna use a 'generic sub-$100-type" code scanner, you're wasting time. But if you really want to do it anyways, there's an OBD plug under the dash, drivers side. But it'll give you "P____" codes, not "DTC___" codes.
DTC codes are mostly covered in the FSMs.
Jovan
May 30, 2006 03:58 PM
PROJECT_D
Dec 11, 2003 06:11 PM
