its my birthday and i want a running 240sx please look in here
Old Feb 24, 2010 | 02:39 AM
justgotta240's Avatar
i was born 18 years ago today (feb 24 1992) and i always loved car games i didnt know what the car was called but as i got older i realised it was a nissan 240sx hatchback i loved them... years later i got my hands on 1 i payed for it with my own hard earned money. i got it about 3 days ago and it doesnt run but ill make it start
i need to know how to drain the gas... the easiest way to drain it does it have a siphon screen so i can just put a hose in the gas tank and suck it out (i have a little pump thing) or do i have to pull the gas tank off
all i want for my birthday is my car to work please help
p.s. does any1 know where to find a 5spd tranny in virginia beach pick and pull doesnt have 240s and every 1 wants and arm and a leg for 1 i looked on craigslist nothing
i know i typed alot thank you for taking the time to read this
Old Feb 24, 2010 | 10:13 AM
240sxnewb91's Avatar
Happy Bday man and you can look on JGYcustoms.com or google jgy performance. its in wytheville VA. im in WV lol about 8 hrs from ya and i will be selling my motor and tranny once i do my SR20 swap. i would go ahead and sell it if i knew i had the sr20 on the way. but if u wanna hit me up sometime ill be more then happy to help ya out as much as i can.
Old Feb 24, 2010 | 12:39 PM
nvrstock's Avatar
im in the hampton area and i may be able to find you a tranny. ill have to do some asking around. If the tank needs to be drained you would probably be better off pulling the tank down and seeing if there is any crap in it.
Old Feb 24, 2010 | 01:03 PM
USMCDrifter's Avatar
Damn . . .1992?
Excuse me while I go kill myself . . .
Old Feb 24, 2010 | 03:56 PM
easiest way to drain the gas is to remove the fuel pump from inside the car and use the little pump u said u have
Old Feb 24, 2010 | 05:31 PM
nvrstock's Avatar
that is the easiest way or you can just take the in line to the fuel pump off and keep the fuel pump on and drain it out that way.
If the gas is really old and has been sitting i would really recommend droping the tank and cleaning it out.
It really sucks when you drain the tank and the all the **** at the bottom gets stirred up when you fill it cause it has been sitting so long and clogs the strainer. then the car wont run
the 240s have a little seperator in the tank for where the fuel pump fits in to keep some of the dirt and stuff away from the strainer but in my experience that doesnt always work.
Do whichever is better for your situation. if the car hasnt been sitting too long just drain it the easy way but if its been sitting awhile (especialy with e10 gas) go the other route and clean out the tank.
Old Feb 25, 2010 | 04:21 AM
gas help
how do i remove the fuel pump from inside the car? i have no idea where it is
Old Feb 25, 2010 | 05:30 AM
On the hatchback it's literally in the hatch, remove any carpet in there and you'll see a port-access for it.
Old Feb 25, 2010 | 10:30 PM
that silver thing under the carpet? next to where the doughnut goes? how do i get that off?
Old Feb 25, 2010 | 10:40 PM
1SXY240's Avatar
it should have 4 10mm bolts, it's a squarish plate
Old Feb 28, 2010 | 08:17 AM
ok so i got the plate off unhooked the fuse and it is rusted to hell and i need to know if i get 1 from online or auto zone will i get the whole thing or just the metal cylinder they show i need a whole new 1 ( there is a pic and pull not too far from me but i dont want to buy a used 1 incase its broke too)
Old Feb 28, 2010 | 08:47 AM
1SXY240's Avatar
I'm sure you can take it to autozone and they will get one for you.
Old Mar 11, 2010 | 01:05 PM
ok so new problem the car starts BUT its hard to start then if i let off the gas it just dies then if i floor it it sputters and stuff im thinking fuel injectors i put seafoam in there and it made a little difference but not much HELP MEEE
Old Mar 11, 2010 | 03:59 PM
run some new gas through it and change the plugs. you probably flooded the motor, so turn it over a couple times with the injector clips unplugged. get it running decently before you try to seafoam it.
Old Mar 11, 2010 | 07:49 PM
its like its not getting gas tho like u have to keep your foot on the gas to keep it running and if u floor it the tac goes up to 2 1/2 then if backfires and starts sputtering and i put new gas like the expensive stuff in there and i already changed the plugs then i cleaned them off when i put new gas in
