Just finsihed my 5-speed swap again!
I got my trans back friday. When i first got it it didn't want to shift at all. I guess during shipping they like to lock up for some reason.
I started taking it apart and i put it back togheter and it worked just fine.
Spent about 1.5 hours getting it bolted all back in and everything. Went to start the car.... Wouldn't start.
I knew the reason but couldn't figure out how to fix the problem. Finally at 2:30am this morning i got it to start and took it for a drive in the snow :blah:
It seems to be running good. Not having a dampener box and a steel braided clutch line makes a huge difference when shifting.
Pix in a few hours, i gotta put everything back in the car
Some things to note for anyone doing a swap.
You can use the auto tranny mount
You only need the reverse, and speed sensor.
You need to loop the bottom connector by the car battery, not the top.
If i think of any more i'll let u know.
thanks, when i took the tranny apart i found a spring on the floor. I believe that its on the the springs that hold the shift forks steady. My 2nd gear comes out of gear if i dont hold it for a while. Think thats the problem.
Originally posted by barcode
so if ya dont mind, you wanna tally up the cost, because i plan on doin the swap to, just wanna get a estimate, i cant help with the second gear thing, im not a tranny guy lol, good luck tho.
Thats with new;
cluctch
p. plate
shift boot
shift ****
tranny mount
and everything else used.
hmm thats not as much as I thaught it would be. Well right now im workin on a S15 conversion, because I got a wrecked 95 SE, that needed a front, so I decided what a better time then now. Just orded the headlights sunday. Had to get some part of the conversion that way I would stick with it lol.
priest19843
Nov 7, 2008 09:53 AM
aug
Apr 1, 2007 04:02 PM
cleanblk240sx
Oct 8, 2005 03:33 PM
long way away but its well worth the wait
