key , (weird)question
Old Jul 7, 2004 | 05:52 PM
PissonH's Avatar
is it me or is it all s14, the fact that i can remove the key when the car is running, while its at on.........anybody else
thanks
Old Jul 7, 2004 | 06:18 PM
S13dude's Avatar
I have a 91. My key doesn't come out unless it's turned off. A friend of mine rigged his ignition to do it. Don't know how or why though.
Old Jul 7, 2004 | 06:45 PM
Chedderknight's Avatar
i have a 91 too and it doesnt come off unless i turn it all the way off and press the key release....thats really odd though...i should research that...
Old Jul 12, 2004 | 04:45 AM
I think your key cylinder (what the hell is it called) is worn out from usage...
Old Jul 12, 2004 | 08:50 AM
ixcocoyxi's Avatar
i had an 88 toyota pickup and i could do that.. i bet you.. if you have some 'nissan friends' you could start your car with their keys
Old Jul 12, 2004 | 02:58 PM
sr20 learner's Avatar
whats a key cylinder
Old Jul 12, 2004 | 03:58 PM
driftae86's Avatar
if i'm correct a key cylinder is the part that u put your key in2 it has all the pins that move up when your key is inserted making it possable to turn the key...
Old Jul 12, 2004 | 04:42 PM
that's the part I'm referring to. Sorry I don't know the real name (can't remember)
Old Jul 14, 2004 | 06:38 PM
Kollide's Avatar
reply
Okay fyi the correct term at least where I work is ignition lock cylinger. It works the same way you house lock works only instead of having just one side with pins and sliders, an automobile and has two sides to work with, except for older cars like chevy and ford and dodge they started off with one key cut for ignition and one for locks, inefficient, YES. So we started double cutting keys to open doors and start cars. Suffice it to say if he can pull the key out he did not "rig" it. Although it is more likey that it is the key that is worn out. Ask him to take a look at it, usually it is the key that wears first constantly going in and out and higher the mileage the more worn the key. Either way both parts wear out and it is just usually the key first though. Sorry that I got on a rant there I am just full of information.
Old Jul 14, 2004 | 08:27 PM
PissonH's Avatar
hi, its me with the key problem , so your saying i should try to change the key first and hopefully that will solve my problem...
thank you
tweak302
Jan 5, 2005 09:38 AM
bomex'd s14
Mar 29, 2004 02:56 PM
kaos
Dec 10, 2002 04:21 PM
StanBo
Sep 23, 2002 04:59 PM
leiferik1
Apr 7, 2002 11:47 PM
