lighting problems
Old Nov 6, 2005 | 09:17 AM
riubens's Avatar
Unhappy lighting problems
hey guys i have a problem with my high beam,every time i turn the high beam on,my left head light turns completly off and only the right side stays on Ive already chked all the bulbs and fuses I think and all chked ok,plus the idiot that sold me the car took off the fuse diaphram in the engine compartment (can some on post one)please guys any insight also i have a 1995 and i bought it with that problem ..hey raine I know you have something logical to say(always do) ...also can some one show me ho to post dam pics always says its too dam big.
thnx..rs
Old Nov 10, 2005 | 02:47 PM
-pics too big - resize with photoshop or something
-are you sure it's not bulb? Did you switch the bulbs from left to right to see if it still did it? If you switched bulbs and the left side still does it, then it's most likely between the harness to the fusebox. I'm too lazy to go out and look but if I remember right each headlamp has it's own relay and fuse under the hood - check it.
The previous owner pulled out a fuse - ok... but which one?
And why did you call me out LOL
Old Nov 13, 2005 | 05:27 PM
jewli's Avatar
I have the exact same problem, I have the same year, bought new bulbs. Its a problem I still have not been able to fix. Usually when the car is on for a while let's say 10-15 mins the second high beam turns on.
Old Nov 15, 2005 | 08:50 AM
riubens's Avatar
hey raine sorry to make you blush,,,,,,j/k
what i mean is the sticker that goes on top of the fusebox,that tells you which fuse is which ,thats why am kind of stuck,i did what you told me jewli and still no lights after 15 min, and yes I already switched the bulbs and same prob,so if any body knows where i could get the diaphram for the fuse box in the internet that would be greatly apreciated.
btw, raine its that i see you know youre stuff (w/240s).ok
ryguy
Oct 2, 2007 08:59 PM
Enlefo
Apr 16, 2007 09:19 PM
240yoda
Mar 14, 2005 06:25 PM
DTS
May 24, 2004 02:53 PM
clts14.5
Nov 29, 2003 12:21 AM
