Lower Timing Chain
Old May 12, 2007 | 01:28 AM
bantothe240's Avatar
Lower Timing Chain
Before anyone says anything, I know I deserve a huge "dumbass" printed on my forehead. About a year ago I replaced the upper timing chain, guides, and lower guides on my s13. Now I can hear the same rattling that I KNOW is the lower timing chain flopping around. The rattle is near the bottom of the engine and frankly, there is nothing else that it could be. I know how to replace it, but I was wondering if there is any way I can get the lower cover off without having to pull off the whole oil pan, which means undoing all that mess with the suspension. (stupid design) Anyways, can I bypass doing all that mess or am I stuck?
Old May 12, 2007 | 10:12 AM
no get in there and remove those guides before they break off on you. also when you are in there check to see if you tensioner is functional by pushing on it. it should go back and forth without much resistance.
Biggamehit
Oct 29, 2007 03:23 PM
Hella 240
Mar 19, 2006 08:33 AM
nschultz0124
Aug 1, 2005 06:22 AM
Imungree
May 15, 2004 04:16 PM
spitz7985
Oct 8, 2002 03:34 PM
