MAF Voltage
Old May 19, 2005 | 07:12 AM
Sevarg710X's Avatar
MAF Voltage
Ok I've been haing problems with running rich and I've tried everything I could think of . I finally got ahold of a voltage meter and check the MAF . Here's where I need help . The FSM says when ignition is on without car runnin it should read 0.2 to 0.4 volts . Mine reads 2.3 which is fine . The FSM goes on to say voltage when the car running and warmed up should be 1.0 to 1.4 volts , but mine's more like 0.86 . So the question is , is my MAF bad ?
Old May 21, 2005 | 05:03 AM
Sevarg710X's Avatar
Bump
Old May 22, 2005 | 10:52 PM
Re: MAF Voltage
It shouldn't read that high with ignition/engine off. What led you to check the MAF voltage? There's other things you should be checking too IIRC
Old Jun 1, 2005 | 06:46 AM
Sevarg710X's Avatar
I decided to check my MAF cause I've pretty much checked everything else .
robalicious96
Feb 17, 2006 06:15 AM
Tanshin
Jul 6, 2005 04:46 PM
dacheat
Mar 13, 2005 09:46 AM
driftfactory
Nov 11, 2004 06:18 PM
drew935
Mar 24, 2004 09:38 PM
