Maxima fan help
Maxima fan help
I have my maxima fans..theres 4 wires coming off of each, I wanna run them so their on when the car turns on. I figure I can tap into a wire in the interior, i ran the wire already, anyone wanna break this down for me? wiring wise?
black is ground blue is power.. .however... please run a relay young nick.
-first run all positive and negative wires together in series
-ground black wire to chassis
-by 75amp fuse and follow diagram to connect.
-run switch to power wire and run it inside of car.
extra
-by a temp switch install and set it to desired level to turn on
extra
what kind of relays, spst or spdt?
there's a write up here somewhere i did a while back if you want to look it over.
not exactly, although in terms of off and on, a spst relay could be considered off-on. a spdt relay however would be more like on-on since there is always a closed circuit, it just alternates.
he doesn't need to alternate, i'm just saying that a spdt relay operates more along those lines than the off-on-off or on-off-on example you gave.
anyways, it's time for another shameless plug so here's my write up.
https://www.s-chassis.com/forums/how-tos-installations-48/electric-fan-install-41909/
the purpose for the relay also young nick is so that Current is alternating and not just straight draining from your battery. when i hooked my fan up without the relay, my voltage would drop from about 13.9 down to about 13.4-5... with the relay it would dip quickly and go back up and stay up.
