msd clueless
Old Oct 20, 2005 | 11:55 AM
chrisramos671's Avatar
msd clueless
i need help installing a msd 6a with a rev limiter can someone help my with a wiring diagram perferable made for s13
Old Oct 20, 2005 | 01:22 PM
don't know if this will help at all
Old Oct 21, 2005 | 07:40 AM
yiaracer's Avatar
i did have a diagram but i don't know where i put it....this is all that i could find. i think the colors are the same.....
on the msd unit-
orange=coil+
black=coil-
white=goes to the black and white stripe wire on the ignition coil harness on the car
thin black wire=goes to the green and black stripe wire on the ignition coil harness on the car
thick black=ground
thick red=battery+
hopefully that helps you out
Old Oct 21, 2005 | 09:34 AM
thanks its helping alot but
orange=coil+
black=coil-
do u mean on the stock coil or on the performance coil (blaster 2)
Old Oct 21, 2005 | 01:26 PM
yiaracer's Avatar
either one...the orange wire from the msd goes to the positive side of the coil and the black one goes on the negative side of the coil
Old Oct 21, 2005 | 04:42 PM
jackyliem's Avatar
make sure you get a tach adapter too cuz your tach wont' work after you install it.
Boost_or_bust
Jun 10, 2007 10:41 AM
S13NismoStyle
Jun 12, 2006 06:42 PM
SagxaZefiro
Sep 24, 2003 07:30 AM
gtracer2b
Jan 25, 2003 02:35 PM
RicerX
Feb 10, 2002 01:49 AM
