my car wont start
Hi I just got my 1991 240sx about a month ago and now it wont start it turns over butnothing I checked the fuel and its not that what else should I check? or what could be wrong with it? Thanks!
if it turns over fine then it's most likely not your battery, but just to make sure get a volt meter and check the voltage while the engine cranks. if it drops to like 5v it the battery.
check any ignition related fuses, coil, distributor and make sure the wires are on correctly.
also just curios about the fuel, what did you check and how? the reason i ask is because you could also be getting too much fuel which would foul the plugs.
Re: my car wont start
haha, i know i was a big poop-head, but there is a "search" button and these procedures are the same for just about every car on the planet, so www.google.com is a great way to keep from bogging down this site, unless you just wanna make friends.
or get your post count up there in the 1000's. but i don’t think it was either one for this girl. she's only had 1 post. odds are she needed help and figured a forum with a specific interest (240s) was the best place to look.
i still would like to know what ever happened with the car. it would be nice to know we actually helped.
well still nothing and being a girl and not knowing where anything is on the car is a bit hard
so i do get a weak spark and gas is going through, i found a loose wire and fuse attached in the ingin its a green 30 fuse and the wires on it a blk and red any1 know what that could be Thanks
