Need Help!!
you have to pull the dizzy half out so that the teeth are free.
after that set cly number 1 to TDC and then rotate the rotor until its at about 10oclock. you will see the notch and also it will line up right where cly number one fires. and its pops right back in. very easy to do bro. after that, you also wanna set your base timing.
you must unplug the TPS to do this properly. if you need info on it, ill provide it.
Jovan
May 30, 2006 03:58 PM
PROJECT_D
Dec 11, 2003 06:11 PM
