Need help
Old Sep 13, 2009 | 12:06 PM
jbt_92's Avatar
Need help
I hooked my tach up and nothing is working except the lights. Im not sure whats wrong. Any information is greatly appreciated.
Old Sep 13, 2009 | 12:11 PM
Nickmerrone's Avatar
why do you need an aftermarket tach?
Old Sep 13, 2009 | 12:24 PM
jbt_92's Avatar
I dont have a after market tach. Its just not working.... After market tachs are for douches. LOL
Old Sep 13, 2009 | 12:38 PM
oh.. LOL. uhhh did you plug it in? lol
Old Sep 13, 2009 | 03:47 PM
gonna need a bit more info.
Old Sep 13, 2009 | 04:36 PM
USMCDrifter's Avatar
It should just plug into the wiring harness. Check the line for a "pulse". I remember my Neon had an aftermarket tach that didn't work . . .I read the Haynes manual and found the proper line to hook it too . . .bam.
If the original connections don't work, find that line (Hit up Autozone, Advance or O'Reilly for the manual if necessary) and get it going.
-Dave
Old Sep 14, 2009 | 04:22 AM
doesn't plug into any wiring harness. you must tap the signal wire into the ignition coil signal wire.
Old Sep 14, 2009 | 07:55 AM
That's what I figured, but I also assumed (probably part of my problem) that if it's the stock gauge cluster that there's a hook up for it or something.
Old Sep 14, 2009 | 10:31 AM
the signal wire for the tach is part of the smaller body harness. to the side of the ecu.
Old Sep 14, 2009 | 06:34 PM
jbt_92's Avatar
Explain? Im trying not to be too slow. lol
Everything is plugged up. I don't know what it is.
Old Sep 15, 2009 | 01:35 AM
the signal wire from the aftermarket tach goes to the Positive wire on the Ignition coil. I made this from the FSM....... the red line is pointing to the location of the wire you must tap into. Its been years since I hooked one up... so you will have to test with a volt meter or test light to see which wire carries the juice. Name:  240sx_aftermarket_tach_signalwire_l.jpg
Old Sep 15, 2009 | 05:38 PM
jbt_92's Avatar
Okay so that helps a little. But its not aftermarket. So I thought it would just plug right in and work.. If this one is just a little *** then i might have to get a aftermarket one..
Jovan
May 30, 2006 03:58 PM
pck3
Apr 25, 2006 12:51 PM
PROJECT_D
Dec 11, 2003 06:11 PM
cheap240
Oct 15, 2003 09:51 PM
RedStage
May 30, 2003 01:13 AM
