problem with exterior lighting
Old Oct 14, 2005 | 02:27 PM
sirenx's Avatar
Question problem with exterior lighting
just wondering if there is a reason why none of my sidemarker lights, front or rear, are not lighting?
also ..the trunk light, 3rd brake light, is not lighting..
i check the bulbs none of the filaments seemed to be burned out..
just found it kind of out that NONE of them were lighting up..
weird coincidence or is there a relay or something that controls those lights?
i checked the fuse box (kick panel on drivers side) and found no burned out fuses..
any ideas would be greatly appreciated.
thanks
Old Oct 14, 2005 | 07:44 PM
Cape 240's Avatar
looks like its time to check some wires!
Old Oct 14, 2005 | 08:19 PM
re037's Avatar
my side markers dont work either. havent bothered to chekc it out as i dont like em on anyways. keep us posted
Old Oct 15, 2005 | 04:06 AM
did you check the fusible links in the engine bay fuse block?
Old Oct 15, 2005 | 06:31 AM
sirenx's Avatar
i had checked them not too long back.. not for this.. but was trying to figure out some other wiring issues.. did not find any blown fuses..
i will go back and check though...
Old Oct 18, 2005 | 07:25 AM
DragonEye's Avatar
my rear tail lights flicker on the one side, i knock on the tail light and it flickers on then a few seconds it flickers off lol. could it just be a ground? or can i just clean off the wires and such and it should be good?
240gonewild
Oct 18, 2007 08:38 PM
240freak88
Aug 15, 2007 09:25 PM
Arsenal
May 19, 2006 01:06 PM
uvamosk
Aug 12, 2005 07:31 PM
Ontario_240sx
Aug 27, 2003 10:10 PM
