Quality Fluids [Sticky?]
From the research and reviews, I've found Royal Purple to be the 'best' Oil.... I figured why not have a list of the best[s]!
Of course there will be opinionated responses, but hopefully after a short while we can compile the ''winners'' into a sticky that reccomends the best fluids....
Oil: Royal Purple?
Brake Fluid:
Transmission Fluid:
Antifreeze/Coolant:
Engine Treatment(s):
Blinker Fluid:
[haha...]
Oil: Royal Purple?
Brake Fluid:
Transmission Fluid:
Antifreeze/Coolant:
Blinker Fluid:
[haha...]
window washer fluid?...lol
is this really nessesary though? because people are going to want to know why these brands are the best...how do you define best anyways?...why is royal purple the best oil? does it have the best compromise between price and quality? or maybe the best price? does it last longer? lubricate better? warm up faster?...maybe it smell the best?
I've seen these questions asked a million times, that's why.. yes, I think it's neccisary. I never said Washer fluid, that's stupid... but seriously, knowing the top products for your car, isn't a good idea, explain that to me..
Every post is going to be flooded with opinion, can't avoid that.. but there are products out there that out perform others, some even cost saving, that's my goal.. to find out what products you can just get the cheap stuff, and what you should spend extra for [Royal Purple] Royal purple is used in the majority of the racing world, not to mention they have a number of benefits over many other synthetics.
transmission - MT90
engine - synthetic 20w50
coolant - 50/50 peak performance (premix
-distilled water + water wetter
dont have window washer
brake fluid - never changed
engine treatment - never used... seafoam i guess
I use Prestone's premix I think, It's yellow... but the 50/50 is way more cost efficiant even if you grab the top brand :]
I did a lot of reading on some forum somewhere, that said you don't even need to upgrade your brake rotors/calipers - Just get new brake lines, performance pads, quality brake fluid and good tires. That if you really needed to you could get new calipers, maybe rotors.... On there was a list of quality brake fluids i'll have to look for it again.
thx nsn
thx nsn
It all depends on the perogative of the consumer. All oils, or fluids (yada, yada) carry there own magical solution (yeah right).
When it gets down to the nitty gritty all oil comes from one place, synthetic oil comes from the same place (recycled oils), it's all the same. Some just add additives to make theres more special to say that it is better than another, No matter what type of testing a company did to say theres is better when it's all the same.
onesloweg5
07-05-2006 09:30 PM
