Question for silviaks2nr
So whats up wid the drawing on the a/t swap electrical? I am steady ordering the parts that are need for the swap, by the way do you have the part numbers for the flywheel bolt, diff bolt and the M/T metal gasket with goes between the block and tranny or do you have a link for all the part numbers for the swap?
Hey what is your email, I will email you the video I just made of the stuff behind the fusebox.
EDIT: go here: I am temporarily hosting the video on my dad's website: http://home.att.net/~btull/Start.AVI It will take it a while to download and mine doesn't say anything while it downloads but after a few minutes it should start to play. It is a .AVI file.
You will have to wire in the neutral position swith (the link i provided in my writeup has a pretty good how-to of it, it does require tapping into a wire coming out of the ECU) and the reverse light swith (easy to do, just run two wires to a sensor from a harness by the fusebox)
