Questions about Antenna
Old Sep 12, 2005 | 01:18 PM
Shainz's Avatar
Hey guys, I am taking out my power antenna since it broke and will only stay fully extended. I ripped out the antenna and the motor, now I am having problems taking out the long rod in which the antenna would sit in while being retracted. Anyone have a diagram or a DIY guide on how I can take it out? I have a stubby antenna waiting to be installed.BTW, its for a 92 240sx hatch.
Thanks,
Roman
Old Sep 12, 2005 | 03:43 PM
ConceptS14's Avatar
you gotta unscrew it. there are 2notches on either side of the hole. i used some needle nose pliers and put either side in each of those notches.
Old Sep 12, 2005 | 04:46 PM
Black240Coupe's Avatar
where did u get the stubby antena from?
Old Sep 12, 2005 | 06:45 PM
Shainz's Avatar
Thanks ConceptS14, Ill try that. Black240Coupe I got it at pepboys for 20 bucks.
Old Sep 13, 2005 | 07:59 PM
Atown 240's Avatar
post pix when u get it installed, i want to do the same to mine. I hate the look of a 3' antenna sticking out the car while ur driving. i like the lil nubs
Old Sep 14, 2005 | 09:25 AM
wikd240's Avatar
if you go to the parts store you can get the tool for removing the antenna... it is well worth the investment in the case that you slip off of the chrome nut... the needle nose pliers works but i would suggest putting electrical or duct tape over the tips so as not to scratch the paint if you go that route...
Old Sep 14, 2005 | 09:38 AM
Frog240's Avatar
you know its funny because when i got my 240 it had no antenna so i bought one of those oem power ones before i realized that without any antenna the 240 amazingly picks up every radio station on the dial.
i say ditch the ugly antenna and if your getting good reception like my hatch does just cap it off.
i guess you could also try an internal antenna but what do i know.
also a 95 and up antenna wont work on a 92, theyre like an inch longer
hope it helps.
Old Sep 14, 2005 | 06:04 PM
ConceptS14's Avatar
^i removed my antenna also, never needed to replace it i still get all the radio stations.
robmiller
Jun 4, 2005 03:15 PM
JR.h1jax0r
Apr 21, 2004 08:38 PM
mezmerize
Feb 21, 2004 10:59 AM
tOfubOi
Jan 6, 2004 09:27 PM
JR.h1jax0r
Dec 29, 2003 05:03 PM
