Questions on sr20
Questions on sr20
Hi i am new to 240's. I dirve a 95 alty right now. I want to buy a 240 with the sr20 swap. My frined is selling one for 6,250 with the black top t28 and bunch other mods. Its in a 92 240. The engines got around 60K. Can i get 180K out of the sr20 with good matness(sp)? Also is the sr20 swap legal in GA? I know they only do the sniffer test. Will it pass? Thanks for your info i am new to 240's but i really want to get one my altys is not sporty enough and a pain in the *** to get any good times out of it. Dont get me wrong i love it! just want another car too.
Thanks for your info.
Travis
Travis
technically, the SR swap is illegal anywhere in the US. here, any swap with an engine that wasn't originally produced stock with the USDM version of the car is deemed illegal unless you have some special title like hot rod people do. but to start off, you should really search the forums first. you'd probably get more information anyway.
-good luck to ya
-good luck to ya
Originally posted by Rusker
He is asking too much, unless there are a bunch of mods you didn't list. The Sr20 will pass emissions if it's running like it should. Then again, I don't know whats done to the motor.
Mods are as follows:
- 1997 Nissan Silvia 180SX Type-X SR20DET
(est. 60,000 miles)
- 1999 Nissan Silvia S15 T-28 upgraded turbo
- Greddy Spec-V Intercooler w/ piping
(dimensions: 36" wide, 24" tall, 3" thick)
- Greddy Front-Strut Bar
- Greddy Type-S Blow-Off Valve
- Greddy 3" Down-Pipe
- Custom 3" Exhaust
- Megan Racing 90MM muffler. (3in inlet, 4.5in outlet)
- Walboro 255lph Fuel-Pump
- Turbo XS Dual-Stage Manual Boost Controller
(High/Low boost switch, mounted right next to shifter)
- ACT Stage 2 Clutch
- Short-Shifter
- Perma-Cool Electric Radiator Fan w/ temperature sensor, or manual switch (your choice)
- JDM '97 Nissan Silvia Limited-Slip Differential (LSD)
- Tokico M 5-way Adjustable Front Struts
- KYB R2 Rear Struts
- Tein S. Tech Racing Springs all around
- 1997 Nissan Silvia 180SX Type-X headlights
(H4 conversion)
- Autometer Boost Gauge mounted inside left-center air vent. Right vent still functional. (glows orange)
- Pioneer CD player
- 16" Eagle Rims
- Front: 205/55/16 Toyo Proxes
- Rear: 225/50/16 Dunlop Z-Rated
Here's a list of some parts I've replaced recently:
- NGK-R Iridium Spark Plugs
- BRAND new Bosch alternator
- BRAND new Duralast Miata battery (lightweight)
- BRAND new brake rotors
- BRAND new brake pads
Thanks bro. Ya i really want to buy it. Im just worried about emmitions i afriad my 95 alty tranny going to go out soon and at that point id just part it out and fine a another daily drive and i want the 240 to be it.
ummm... i hate to tell you this but it really doesn't matter even if your car passes emissions...
it will still fail if the mechanic realizes that it isn't the stock engine... This swap is 100% [B] illegal [B] for street use. Now that doesn't mean that it won't get a sticker.... Most of the time people are stupid and therefore don't realize it's a different engine so if it passes emissions your ok. Or even if it fails emissions there are ways to get around that...
All of this is simply to say technically any Certified Car Inspection shop can fail your car in a heartbeat. Doesn't mean it will happen, but just so you know.
Clarke240
Sep 25, 2007 03:38 PM
JeffSchmitt
Apr 30, 2004 11:25 PM
