Quick heater question 96 se
Old Jan 18, 2005 | 02:12 PM
needa240's Avatar
Just got my 96 se a month or two ago.
The heater is VERY weak. It barely warms anything. I live in so cal so i know that it's not cold weather causing it.
What could be causing my heat to barely get warm? It blows just fine, and the ac works perfectly.
Second. Could it POSSIBLY be anything in the "heater box" under the dash that is causing it? I have access to the entire unit for free, but i don't know if it would be worth paying the shipping if nothing in it will solve my problem.
ANy suggestions would be GREATLY appritiated.
thanks!
Old Jan 18, 2005 | 02:53 PM
cmhadley's Avatar
just a suggestion
you might want to check and make sure the slider for the cold to hot is functioning properly...my friend's crx had the same prob and whenever he wanted to switch from cold to hot he had to reach under the dash and there are metal rods that change the blower temp...not 100% sure it is the same on our cars, but wouldn't hurt to look
Old Jan 19, 2005 | 10:41 AM
Re: just a suggestion
Yes, you're referring to the airmix door.
Did you do the usual checks first? (heater hoses, watercock)?
Old Jan 19, 2005 | 12:10 PM
needa240's Avatar
heater hoses are ok.
Watercock??? where that, and how do i check it?
Old Jan 19, 2005 | 12:37 PM
valve-looking thing on the heater hose... there's a cable that is connected from the airmix motor to the watercock... if this binds, the airmix door won't move
Old Jan 20, 2005 | 10:46 AM
Darren337's Avatar
if the cable binds, wouldnt the lever not move?
Old Jan 20, 2005 | 01:39 PM
the cable is mechanical, but it's attached to an electric motor that controls the airmix door.
The lever will move because the HVAC controls are also electric, not mechanical.
Old Jan 20, 2005 | 02:29 PM
Darren337's Avatar
oops, "connected to motor" didnt register when i read it. Any danger of burning the motor out because the cable binds?
Old Jan 20, 2005 | 10:10 PM
I don't think so - it'll just try to move but it won't. I had that exact problem when I was diagnosing my "lack of heat" - the airmix door wasn't moving, so I disconnected the watercock cable from the motor lever and bam - airmix door fixed.
Instead of buying a new cable, I just leave the watercock set in the open position under the hood
nvrstock
Oct 25, 2005 03:59 AM
lrb_2000
Nov 23, 2004 11:44 AM
mlush
Nov 3, 2004 08:43 AM
arpop
Nov 27, 2003 03:43 PM
s13_bb2.
Nov 23, 2003 07:54 AM
