Radiator Install, 56K HA!
After months of holding it off, I finally installed my Aluminum KOYO Radiator. The Install was very easy, took my friend and I 5 hrs, and that included us f*cking around, A LOT.
The Install consisted of..
Radiator.
FAL Fan, 210 Version.
Samco Red Hoses, yea..cheesy.
Greddy Coolant Temperature Tap
Greddy 52mm Black Temperature Gauge
sorry for the blur, I'll take better pics later..
From this....
to this...
then finally this...
Misc....
Radiator.
From this....
to this...
Misc....
nice... i did the same writeup a while back minus the fans. I need to get some of those FALS... the 210s are just straight wire in right? none of that ac fan sh*t
http://www.club240.com/forums/showth...mance+radiator
Originally posted by PNG
Nice. Hopefully I'll be putting a Koyo in this weekend, too.
But please, PLEASE take it from somebody who's had an electrical fire - get a real battery tiedown to replace those zipties ASAP....
Nice write up, I was thinking of doing this since I have to get a new radiator anyway, how much did this set you back, fans, radiator, and new hoses?
The Battery is temporary, it's being relocated to the back as soon as the kit comes in.
For the fan wiring, my friend did it..and it took him 30mins, very easy, and very straight forward.
A couple of things I did wrong on this install..
The Gauge is ALWAYS on. I tapped it on the wrong wire..and since that happened..I ended up blowing the gauge itself..so I'm F*cked there.
As you can see..I'm running 3 gauges..The first 2 is running off the the same tap, but I decided to tap the 3rd one on another line..THE QUESTION is can I tap all 3 gauges in one?
I suck @ car electricity..and It's paying off.
depends what you are tapping into... i have my power for my defi control unit in the radio power, and cig lighter pos and neg. works awesome, since i only needed to do wiring once for up to 8 (i think) gauges
In your case... i'd try to split it up... wuick options i can think of... cig lighter, radio power (theres more than one) ecu power might work, anything that is on when the ignition is on... if they are all in one wire, you might blow the gauge (not enough power) or have them be really dim/ blow fuses
edit: download an fsm... wiring diagrams are very easy to read, just dont freak out lol. that will tell you everything you need to know
Originally posted by nsn240
hey man! why didnt i get all the support with my write up?!
Is it in the turbo section?????
I'll check it out let me look for the link.......
EDIT: I searched, and cannot find......
Originally posted by BigVinnie
Which one
Which one
(you know that same link is a little further up the page right? )
Originally posted by s13 240
you want some "waaah burgers" with your "french cries"
i knew i should have included another smilie after the " " one
