Radiator Question.
Old Jun 20, 2007 | 01:21 PM
clubredsilvia's Avatar
Radiator Question.
will a s14 radiator fit in an s13? I got another '92 240 for $200 and all it needs is a PS rack and a rad.
Old Jun 20, 2007 | 01:24 PM
yes it will. you will just have to use the s14 mounting brackets. also the best thing is the electric fan that comes on the s14 can be used for great cooling.
Old Jun 20, 2007 | 03:43 PM
-sweet, thanx. i don't have the s14 brackets, tho, so i will have to make some. Also didn't come with the fan.
Old Jun 20, 2007 | 04:41 PM
blurryeyes's Avatar
for the fan try one from an altima if you can´t find one for the S14
Old Jun 20, 2007 | 05:45 PM
or just flip the s13 ones upside downward and there are two small wholes inside where u can shove some bigger bolts into..
Old Jun 21, 2007 | 06:08 AM
-Also willa Sohc power steering rack work in a twin - cam? I know thw resevoir is on the other side, but are the sizes any different? If it matters, i will not run power steering, so the rack will be capped off, and it dosen't have to connect to the pump.
Old Jun 21, 2007 | 08:05 AM
yea you will just need the high pressure hose from an s14 and you will have to bend them a bit to make them fit
Old Jun 21, 2007 | 08:13 AM
^^^ Idon't want to hook the pump up, tho, so how would i cap the rack. I use the s14 HP hose to cap the rack? please explain.
Old Jun 21, 2007 | 01:27 PM
oh no to cap the rack.. all you have to do is leave a bit of fluid inside of the rack and take some 14mm bolts and jam them in the rack.. the bolts i inserted in my rack hardlines still remain a whole 4 years later.
OutToWinPAHC
SR
Jun 27, 2007 08:04 AM
buyMEbeerPLEASE
Feb 9, 2007 08:10 AM
dak2007
Apr 17, 2006 05:30 PM
boostedfury
May 25, 2004 10:38 PM
StanBo
Jun 11, 2002 06:26 AM
