removing rear quarter glass?
anybody know how to get the glass off? this guy told me use rope to cut through the sealant but how do u get the rope in there in the first place??? i cant find any spots in the moldings that i could pry up/pull off to stick anything inside. thanks for any info!
yay! for being vauge.
the rear quarter windows. you know...the ones in the back with "240" on it(s13 hatch chassis). just wondering if anyone knew before i start going nuts on it with my screwdriver and hammer. =P
sorry for the vague-ness |
you have to floss the sealant out. thread the floss through the sealant(i don't know how) and floss all the way around the window.
what u have to do is get some piano wire. it really thin string made of metal with notches on it. All u have to do is remove every thing around the window away and gentally take a very thin flat heat screw driver and or pick and poke a hole through the rubber on the window. After that insert the piano wire through the hole, have a freind pull the string on the other side and u work ur way all the way around, once u began to work briskly, the string will began to heat up and actually melt the rubber
u can get the wire from home depot for about 99cent. All u need is about 15 to 20 inches of it. ps. did u get 180xs quater glass ps dont use a hammer, i loss a glass that way my very first time idid it. it would also help if u heater the pick up red hot then poked the hole through |
Is it possible to even put the 180sx quarter glass on the 240.
I was watching that canadian Shift 180sx video and the dude couldnt put his glass on cuz something with the molding was cut...? |
yes it fits, when laying down new glass u are suppose to clear out all the old rubber compond and buy new compond. you can get it from advance auto for about 10 bucks. u will get more then enough to do the project. all u do is lay down a single layer and then place the glass on top of it and apply pressure.
please make sure u get it right the first time because its a one time shoot, the sealant is very sticky. if u dont u will have to pull the glass up and put another layer of sealant on. |
Originally posted by RuizXIII Is it possible to even put the 180sx quarter glass on the 240. I was watching that canadian Shift 180sx video and the dude couldnt put his glass on cuz something with the molding was cut...? |
no i didnt get 180 glass. im gonna start molding the rear wide fenders on as soon as i can get the glass off. and it'll make a much nicer paint job. the faster i get these windows off the faster i can paint! =) thanks for all the info.
ps. i am considering getting 180 glass. 375 at a local shop. -___- |
Originally posted by toycar ps. i am considering getting 180 glass. 375 at a local shop. -___- |
not bad.... well still im in no rush to buy them. id rather put that money into a d-drug wing :)
how bout a heat gun from homedepot
Originally posted by toycar not bad.... well still im in no rush to buy them. id rather put that money into a d-drug wing :) |
emailed u
Originally posted by silviaks2nr how bout a heat gun from homedepot the piano wire will have the window out in about 5min of brisk working |
