S13 coolant leak
Old Jun 23, 2008 | 11:26 PM
supra33202's Avatar
S13 coolant leak
I found the coolant leak. I want to confirm that I need to replace the water pump. If yes, I will follow the guides.
http://forums.********.com/zerothread?id=220947
http://forums.********.com/zerothread/242595
http://www.youtube.com/watch?v=nDysgdtBzVA
And about the rattling noise, is that the infamous timing-chain-hitting-the-guide noise?
http://www.********.com/articles.php?id=105618
Thanks!
Old Jun 24, 2008 | 03:33 PM
the noise doesn't sound like it's the chain at all, i'd say it's your water pump saying it's last words.
Old Jun 24, 2008 | 07:22 PM
first check all of the hoses around the top radiator hose area. if they all check out than yes it is indeed your pump and it sounds like a super charger when its really going up
Old Jun 25, 2008 | 12:25 AM
supra33202's Avatar
Sorry of the noob question, what are the two lower right pulleys for?
Old Jun 25, 2008 | 02:23 AM
Ac
Old Jun 25, 2008 | 08:49 AM
supra33202's Avatar
There are 6 pulleys.
Left: Alternator
Top center: Water pump
Bottom center: Main engine pulley
Top right: Power Steering
Bottom far right: ?
Bottom (between main engine pulley and far right pulley): ?
Which one is the AC compressor?
Old Jun 25, 2008 | 12:01 PM
o.g.darkdrifter's Avatar
AC compressor is the bigger one. If memory serves me right it's below the power steering pump. If it comes down to it just trace the ps lines from the resorvoir into the pump and through process of elimination the AC compressor isnt that one so that only leaves you with one more pulley on that side.
Old Jun 25, 2008 | 12:05 PM
yes Ac is bottom right with and idler pulley to the left of the pump
Old Jun 26, 2008 | 08:28 AM
supra33202's Avatar
Thank you everyone.
I finished replacing the water pump yesterday. I didn't see any more leak, but I will check again tonight.
I still hear the rattling noise. I think it is the chaining guide.
Old Jun 26, 2008 | 10:25 AM
Did you remove the chain tensioners? There are two that you can remove. Look it up on the boards you'll find all the info you need on the process. If your ish is already rattling I'd remove them immediately so you dont get any major damage.
slidewithpride
Aug 12, 2011 09:51 AM
KAMAKAZI 13
Sep 24, 2006 11:08 PM
yektik99
Jul 17, 2006 10:46 AM
Whinin
Apr 20, 2006 06:48 PM
wrpspddrvr
Sep 29, 2004 07:20 PM
