s13 radiator problem
Old Apr 11, 2009 | 06:02 PM
smoken805s14's Avatar
so i'm having this problem where my car overheats ...it did yesterday and it did almost a week ago...i pull over and i check the coolant and it's full so i have to open up the top of the radiator to put in the fluid manually ....why isn't it getting the coolant from the coolant box???i changed the thermostat...and i still have a small leak from the little U shape hose....prolly going to change it tomorrow i just have to pull out the alternator to get to it....but to hold of the leak a little bit i bought this stop leak at kragen to hold it off for a bit....and before i put that in i flushed the radiator....i need help thanks...
Old Apr 11, 2009 | 09:24 PM
so just to be sure i understand. you have a leaky hose so you bought some stop leak stuff? if so flush that stuff out, and use plain water. after you do that and have taken care of any leaks be sure to bleed any air bubbles out.
Old Apr 11, 2009 | 11:25 PM
ok but how do you bleed out the air bubbles? and by flushing it out my radiator problem will be gone?
Old Apr 12, 2009 | 12:10 AM
there's a bolt on the intake manifold with a warning sticker next to it. that's where you bleed it from. but first you need to get that stop leak out. that stuff is worse than having a leak because you can at lease keep adding coolant or water. that stuff can plug up your radiator and prevent the flow of coolant. so first tend to the leaks then flush the all the coolant out, refill the radiator and bleed the air.
if i'm right this will eliminate the overheating assuming that air pockets of air were you problem to being with.
Old Apr 12, 2009 | 11:30 AM
ok so after i flush out the coolant i go to the bolt on the intake manifold and what do i do to bleed it?? i know when you do your brake lines you push the clutch in and out but how would i go about to bleed this?
Old Apr 12, 2009 | 03:27 PM
FuriousZ's Avatar
Bleeding is a term used to get rid off air in lines or system in this case cooling system. There is no pedal to pump. Just air to get rid off.
The best thing to do is download a FSM (factory service manual) or buy a hard copy. But download is free. you just have to search.
It will give you a very specific instructions on how to do ANYTHING to your car, from bleeding coolant to checking electrical components to disassembling the engine.
Download an FSM.
vortxxe
Apr 29, 2006 05:22 AM
lionel
Sep 12, 2005 08:15 AM
uvamosk
Aug 12, 2005 07:31 PM
Sil80guy
Mar 11, 2004 07:56 PM
NiNJA323
Feb 1, 2004 07:46 PM
