S13 steering play
Old Jun 8, 2009 | 09:03 AM
supra33202's Avatar
S13 steering play
I have about 1 inch of steering play on my 1993 S13 hatchback. So I installed new tie rods, new tension rods, new steering rack bushings, and new aluminum steering column bushing.
I also have Stance CR+ coilover, and all other SPL control arms.
What else should I do to eliminate the 1 inch steering play?
Thanks!
Old Jun 9, 2009 | 12:36 AM
must replace steering shaft bushing.
sort of a pain with the enigine in on USDM cars, but can be done.
easy with engine out if you are putting one it.
if you are going to go through with it, make it aluminum and make it worth while.
Courtsey of N I C O club since there is no write up for it here.
http://forums.n i c o club.com/zerothread/229603
Old Jun 9, 2009 | 08:21 AM
supra33202's Avatar
I installed the new aluminum steering column bushing already as I mentioned in the original thread. The is the reason why I posted. I installed everything that I can think of now, and I still have the 1 inch play.
Old Jun 9, 2009 | 12:22 PM
1" of free play after replacing all that you have mentioned is not a lot. but you could check linkage for loosens.
Old Jun 9, 2009 | 05:31 PM
oh wow i didnt see that part.. have you calibrated your Rack????
Sircnay
Jun 24, 2003 09:53 AM
rudeboy
Dec 17, 2002 10:23 AM
malicex000
Oct 16, 2002 05:32 PM
UnderAgeEnthusi
Apr 24, 2002 08:50 PM
