S14 JDM Headlights
Old Apr 13, 2005 | 11:03 PM
Thanats's Avatar
S14 JDM Headlights
I just recieved my S14 JDM headlights, does this headlights use the same bulbs as the USDM?
beacause the high beams doesn't seem to be.
thanx
Old Apr 14, 2005 | 02:56 PM
hmmm, watch out about the glare the headlights cutoff goes up to the left so you may get people flashing you. as far as i know the usdm and jdm use the same bulbs... just take the burnt out one to the store or w/e
Old Apr 14, 2005 | 06:31 PM
Thanats's Avatar
The high beams Im sure are not the same, but I don't seem to identify the JDM high beam.
Old Apr 15, 2005 | 12:24 PM
Get pics of those bad boys.
Old Apr 17, 2005 | 12:24 PM
samms95s14se's Avatar
Here is a pic of mine only the high beam conector is different and you need the jdm conector that I dont have but I still have high beams when I turn them on just not from the actual high beam bulb.
Old Apr 17, 2005 | 12:43 PM
Thanats's Avatar
yeah, the conector its diferent because the bulb its diferent, I just changed the USDM high beam socket for the JDM socket, no big deal, but my question its what kind of bulb its the JDM hig beam?
BTW samms95s14se nice ride, the silvia grill its green or black?
Old Apr 17, 2005 | 06:44 PM
The Jdm high beam bulb is an H3 which is easy to get I just need the wire with the jdm conector on it to splice in but for now the low beams work as high beams too. And the gril is painted black.
Old Apr 17, 2005 | 07:01 PM
Thanats's Avatar
So, the JDM high beam bulb is the same as the fog light, H3?
Old Apr 30, 2006 | 05:26 PM
barcode's Avatar
my jdm high beam looks different from the regular H3, instead of the bulb having a wire coming off of it it has 2 prongs connected, i can find a bulb like this anywhere, i really need one cause, well i will post a pictue in a while, once it gets dark.
Old Apr 30, 2006 | 05:48 PM
probably an hb3 then
Old Apr 30, 2006 | 07:17 PM
barcode's Avatar
ahaaa, any idea where to get those, i couldnt seem to find them...guess ill keep lookin.
edit: i looked at those and none of the pics looked even close to mine... hmm
Old Apr 30, 2006 | 08:10 PM
barcode's Avatar
well heres som pictures of the bulbs. and the main reason im tryin to figure it out now, well you will see in the pictures.
here
here
and this
^^^i was moving lol...my bad.
Old May 1, 2006 | 12:34 PM
barcode's Avatar
well i found the kind of bulb it is finnaly, so if anyone needs to know
The high beam in the JDM S14 lights is a H3c bulb.
Old May 3, 2006 | 12:02 AM
Dj Suppai Saru's Avatar
Where did you get these headlights and how much did u pay 4 them?
Old May 3, 2006 | 02:10 PM
barcode's Avatar
i found some fairly priced at this place http://www.racinglab.com/ . they have alot of lights lol.....ALOT
weei2
Aug 5, 2006 10:26 AM
S14ninja
Feb 16, 2005 05:40 PM
fulloption86
Jan 12, 2005 11:15 PM
dateddybear
Apr 8, 2004 06:50 PM
gsgoodies818
Jan 2, 2004 01:21 PM
