s14 throttle position sensor
Old Jan 5, 2006 | 02:06 PM
Enlefo's Avatar
How the hell do you unplug this thing?!? I found the TPS on the side of the thottle body. The clip that attaches it doesn't seem to have any prongs to push down or anything. I messed with it for a few minutes last night but I don't see hot to take it off. Anyone had to change theres or unplug to set the idle?
Old Jan 6, 2006 | 07:53 AM
Preston's Avatar
If the same as s13 (I am sure it is) there is a spring on it that you need to undo then it just pulls off. Don't lose the spring though.
Old Jan 6, 2006 | 08:49 AM
Roastem's Avatar
There is a wire clip that goes around it, you will need a small screwdriver or something to wedge under it and lift so that it will pass over the tabs that hold it on.
Old Jan 6, 2006 | 12:57 PM
Enlefo's Avatar
hmm... I couldn't see any sort of clip/wire on the outside of the clip. I'll check it out with some more light later tonight.
smoken805s14
Sep 30, 2008 07:09 PM
smokin240
May 19, 2006 02:03 AM
sirenx
Oct 25, 2005 08:34 AM
CowboyTurbo
Jul 28, 2005 07:41 PM
SoloDrift1
Mar 11, 2003 05:21 PM
