-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Severe batt drain question (https://www.s-chassis.com/forums/general-3/severe-batt-drain-question-46245/)
aero528 Aug 11, 2009 11:01 PM
I have a friend that is looking into getting an auto 93' 240 for $200. The engine runs great, with not much rust. The only real problem is a batt drain. Whenever you plug the batt in, it drains in about 5-10 minutes. I haven't been in the 240 scene in a while, so I forgot a lot of info. Any initial ideas on where that drain might be from? Any common places to check? Might have a blown relay, could that be it? Thanks for the info.
Biggamehit Aug 12, 2009 08:18 AM
check engine cont fuse in bay.... if popped batter will not charge and it will die.
aero528 Aug 12, 2009 11:00 AM
Thanks, I'll try that once he gets it.
240smoke Aug 12, 2009 01:40 PM
Start checking continuity between power and ground and pulling fuses.
aero528 Aug 19, 2009 10:58 PM
Ok, got some more info. The batt will die within 2 minutes of connecting. Still haven't gotten delivery of the car, so can't look at it myself, just looking for ideas.
