Simultanious Brake and Battery Light
Old Feb 17, 2004 | 05:10 AM
Ladybug's Avatar
I'm not sure if this is an electrical issue or not, cuz i'm new to this car still....
just making sure this isn't a warning for something else?
the brake and battery light are coming on simultaniously.....buzzing in and out, staying on for a few minutes, then going out. it does not seem related to speed, turning, braking, or acceleration.
any clues?
Old Feb 17, 2004 | 06:15 AM
crimsontide240's Avatar
i would say electrical....but you never know
Old Feb 17, 2004 | 11:09 AM
drnovascotia's Avatar
in my dads saturn that meant low coolant, check the owners manual and it will tell you.
Dr.
Old Feb 17, 2004 | 02:25 PM
devnull's Avatar
You should have your alternator bench-tested.
On the 1st gen altimas, if the brake and battery lights come on, the alternator is dead/dying.
Old Feb 17, 2004 | 02:28 PM
Ladybug's Avatar
i have read in one other place that it vaguely refers to the alternator......it's been 24 hours since the problem, and the car is still starting......i'll be checking the alternator and belt
also, on another forum, a guy is having the same issue and seems to think it's a wire grounding out....yet another reasonable answer!!
i checked the original owners manual, and there is nothing that refers to both lights coming on at the same time
Old Feb 17, 2004 | 03:32 PM
I would think its a electrical problem, grounds, crossed wires
Old Feb 17, 2004 | 05:30 PM
eliterit's Avatar
on my 93 sentra , when i would get the brake and battery light that's when my alternator went out.
happened twice already
Old Feb 17, 2004 | 05:37 PM
tommyboy's Avatar
My 92 is doing the same thing. I put a voltmeter on the battery and started the car. It showed that there was no charge being put into my battery. You could just stand there and watch the volts drop.
Old Feb 17, 2004 | 06:00 PM
JeromeS13's Avatar
So, what was the minimum voltage while the car was starting? What was the battery's voltage at rest? What was the voltage while the car was running at idle?
Old Feb 17, 2004 | 06:03 PM
tommyboy's Avatar
The thing wouldn't barely start under 11 volts. It held that voltage for a few minutes and then started to fall at idle. Then the car would die. Sitting, with a full battery would be 12.85 volts. Then a few starts and it was shot.
Old Feb 17, 2004 | 08:52 PM
devnull's Avatar
With no load, the battery should be at ~12.5 volts.
While cranking, the battery should not drop below 9.5 volts.
When the engine starts, the alternator should be active and the battery should be at 14-14.5 volts. If it's above or below that spec then the alternator is bad.
Old Feb 18, 2004 | 09:51 AM
14-14.5? I wish
13.6- 13.8 on every car i've ever done.
12.6-12.8 normally.
He's right though, if it's below 13.6 while running then it's the alternator.
Dr.
Old Feb 18, 2004 | 10:10 AM
Ladybug's Avatar
heh, i sourced it to the cig lighter.....grounding out
Old Feb 18, 2004 | 10:43 AM
tommyboy's Avatar
Glad it was only the lighter. I have a pain in the a** job ahead of me taking out the alternator in 30 degree weather
Old Feb 18, 2004 | 01:36 PM
Ladybug's Avatar
oooooo....that's not fun (move to florida )
