So i got my sr dyno'd
Like the title says, i got my sr dyno'd today on a dyno jet. not very impressive numbers.
98 s13 blacktop, stock t25, 3inch downpipe, testpipe, exhaust, fmic, arc air box, 11psi, walbro.
202 hp and 205 ft/lbs
its a shame it doesnt have the afrs on there.
it seemed kinda low to me. i dont know. the car was run slightly lean for a couple of weeks and i hope that didn contribute to the low numbers
p/s yes. no a/c. i really thought that i would be a little higher than that. ive read that people have hit much higher than that running the same setup. but ive also seen lower as well. oh well, i got a new turbo at the house that i should hopefully be putting on soon here.
yea bro... thats the stock numbers dude... you really don't have anything done...
bolt on mods just help assist the motor... if you didn't have what you have the numbers would be lower.
This is why I dont see the point of going sr when you can build a reliable ka-t for around the same price as doing a complete sr swap, in the end you will probably have more power out of the ka-t and it can be just as reliable if built correctly. 202hp and 205ft/lbs sounds right to me. lol That would be more than enough for me.
Not exactly true. It will drop off more relative to the peak, but the peak and drop off points will still be higher overall. If you run 15-17psi, you will get a massive increase in tq and hp, and depending on the health of the turbo and if you get an upgraded actuator, you can get the fall off point above his current 11psi. My last stock turbo setup with an HKS actuator and EBC made 1.2 bar (17psi) and dropped off to jsut under 1 bar (about 14psi) at redline. Made over 250whp. Switch to a T28, z32 maf, and bigger injectors, ad 300+ is obtainable.
yea i don't knock SR guys at all... got to many buddies for that... the KA-T was just fun for me to build and i tune it myself... so i have to seek no outside help... if your skills are lacking and you don't have the drive to learn.. the KA-T is not the route for the timid.
yeah it feels much better than the ka. i guess ka vs sr all goes down to prefrence. i like the way the sr feels alot more when im driving hard in the mountains. it revs much easier and likes higher rpms much more than the ka. but back to staying on topic.
I just wanted a baseline run before i put on the new goodies. hopefully by the end of next week ill have my GTiR turbo w/ s14 comp housing on, 550's, enthalapy tune, and the ichiba mani. thinking about some bc cams too but those can wait. hopefully ill be able to hit 280-300 with that setup.
right now my SR isnt in my car yet but so far i got
-tomei expreme manifold
-Garrett GT2871R
-full 3" turbo back exhaust
-740cc injectors
-AEM EMS
-z32 MAF
-Greddy Type-M Intercooler
-Nismo FPR
pretty much it other then pullies and stuff im hoping to make a reliable quick spooling 300+whp i might get the Tomei Poncams i heard they are really good yet very mild and streetable
-Garrett GT2871R
-740cc injectors
-AEM EMS
-z32 MAF
-Nismo FPR
